ok
CHOOSE YOUR LANGUAGE
DS Default Plans
There are two kinds of DS default plans as below:
  • System Plans
  • Common UI Plans
If the foreground app has a self-defined plan conflicting with a DS default plan, the DS returns the plan which was defined by the foreground app.
1. System Plans
A system plan is a DS default plan that has system behavior on devices, such as the end plan, the go-back plan.
Listed below are our predefined system plans.
2. Common UI Plans
In contrast to a system plan, a common UI plan is a DS default plan not having system behavior. Common UI plans are plans that usually appear in every activity. This type of plans only allows the foreground app to trigger them.
Listed below are our predefined common UI plans.
Go To Top
